Question about Pride New Mobility Rally 4 Wheel Scooter
Scooter beep but wont run
Scooter beep then beep 5 time wont run
    Novelist:
  • 60 Answers
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. Th is device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Posted on Jul 29, 2012
SOURCE:
Why my hooverround scooter keep beeping when I turn the key is on
"Apparently" it MATTERS how many beeps you have? Your Scooter is trying to communicate with you!
Please see this series of posts:
https://www.mobilityscootersdirect.com/forum/knowledge-base/pride-go-go-mobility-scooter-beeps-5-times
4 TIPS TO RESOLVE COMMON MOBILITY SCOOTER AND POWER WHEELCHAIR ISSUES
4 Tips to Resolve Common Mobility Scooter and Power Wheelchair Issues
Anthony
Jul 09, 2018 | The Health & Beauty
Wont move 5 beeps and freewheel lever is properly engaged
hi Cornelius,
Check the micro switch located on the brake, if that working okay as sometimes they stick... if the controller can't see the brake resistance it will bleep five times...
then check the connections from the axle to the frame , four connectors , tow for the motor and two for the brake.
Feel free to call me if you're located in the UK
Regards
Rob..
Dec 03, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My gogo ultra is showing fully charged and horn beeps, when i put key in it beeps fast 10 times and 5 beeps after
5 beeps usually means scooter is out of gear, but since the lever is in the drive position and the scooter gearbox/differential is engaged, it seems that the controller is not sensing the gear change. Possibly a faulty micro switch in the motor housing can be the cause of this, usually the micro switch is pressed down by the drive lever and if the switch is pressed down the motor controller knows the scooter is in gear.
Feb 11, 2015 | Pride Mobility Products GoGo Ultra X...
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
What does 5 beeps mean In POST test on a revo power scooter
The beep code 5 normally means a Brake problem. Check wiring, Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Jun 15, 2014 | Electric Mobility Mobility Electric Power...
Electrics wont work
Please be more specific. Any flash or beep codes? Make\Model\Year of scooter? Is wig-wag pot {potentiometer} within tolerance? [5,000 ohms +/- 5%]
Mar 13, 2014 | Health & Beauty
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
Apr 16, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I HAVE A PRIDE 3 WHEEL GOGO SCOOTER. THE BATTERIES WENT DEAD. I REPLACED THEM AND CHARGED THEM UP. NOW I GET A 5 BEEP CODE WHEN I TRY TO START. IS THERE A LIST OF WHAT EACH CODE IS? THANKS FOR YOUR...
Hi Fred,
Good job on replacing the batteries!
With the go go scooter, a beep code of 5 indicates a solenoid brake trip. This means that the brake manual/freewheel lever may be in the freewheel position. This means that you can push the scooter. Remove the key and push the freewheel lever to the drive position. Restart the scooter and the code should be cleared and the scooter will run. Hope this helps.
Jan 19, 2011 | Pride Mobility Products Go Go Ultra X 3...
When I turn the key on it beeps 10 times and then pauses and beeps 5 times. The manual says that the five beeps indicate the manual freewheel lever needs to be put in drive. I did exactly as the manual...
The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Dec 23, 2010 | Pride Mobility Products Go-Go Elite...
Pride New Mobility Rally 4 Wheel Scooter Logo
528 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
