Whirlpool washing machine awm-258 nordic cold water inlet does not work anymore...
Please check on the voltage on the inlet valve , check on the controller if there is no voltage if not the inlet valve is faulty.
click this link: inlet valve
Testimonial: "Helpful so far. I gently tapped the solenoid and the cold water inlet worked again, but the machine stops in the middle of the program."
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
SOURCE: washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
SOURCE: my washer whirlpool awm 258-1200 nordic makes
your machine and indeed every washing machine has a large cement brick on top of the drum inside if this gets loose or breaks it knocks the machine of balance causing the machine to make a bumping sound mostly when starting.adrian,,,,
Testimonial: "relevant, timely and excellent feedback"
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect.
If the
water flows though the inlet then the flow pressure should be good, if not the
inlet valve is bad or there is dirt in the filter. Also check the flow at the
inlet of the water line. Once the water comes into the system the WATER LEVEL
SENSOR - normally a pressure switch- must activate at the preset/chosen level
to give the signal to the program controller to switch on the motor. What is
most important for the motor to start functioning is that the door switch must
be ON when the door is shut or this will be an error for starting the motor for
rinse and wash.
