Driver's window
The wiring diagrams for your 2003 GMC Sierra power window circuits are copyrighted material and cannot be posted here. However, I can describe the driver's power window circuit to you.
Battery voltage is provided to the driver's window (master) switch via the ORANGE wire at PIn #2 on the switch connector which comes from the 25 Amp Left Window Circuit breaker located in the fuse block on the left side of the dash.
There is a logic module located inside of the master switch which controls the "Auto Down" feature for the driver's window. When the switch is operated in either the "UP" or "DOWN" position, power and ground is supplied to the window lift motor via the BROWN wire (Pin #1, Connector 2) and the DARK BLUE wire (Pin #3, Connector 2) Thease wires will switch polarity dependin on whether the switch is commanding UP or DOWN.
The schematics show that the ground circuit for the driver's window motor is supplied internally by the driver's window switch module. It is most likely grounded inside the door panel itself - the schematics do not specify. To check for ground, you can test continuity to ground on BOTH the BROWN and the BLUE wires by back-probing them with the switch electrical connector plugged in and the window control switch in the NEUTRAL position. They should both have ground.
When the switch is operated, one will remain ground while the other switches to power.
