I have downloaded radio podcasts from the internet onto my PC and cannot copy them onto my sansa clip by dragging and dropping or copying and pasting onto the podcast area - I get an error message saying I do not have permission to create this item. I have an identical sansa clip and do this all the time on that one.
SOURCE: Problem with drag and drop
(FOUND THIS SOLOUTION ON AFTERDAWN.COM) The problem is that this player have 2 standards for connecting to PC. One is MSC and other is MTP. Each one have different directories structure. If you put music when your player is connected as MSC, when you will conect as MTP you'll be not able to see the files uploaded previous. The same case is available when you write music files as MTP=> you can't see these files in MSC mode. So, set USB mode of your Sansa as MCS, power off, put hold switch to lock and connect to PC. You will see 3 directories: Audible, Records and Config (or something like that). See if your "invisible" music files are here. If they aren't connect as MTP. To connect as MTP: set USB mode to auto, shut down Sansa mp3 player, put hold switch to unlock and connect to PC. You will see only 2 directories now. Media and "something" (I can't remember now). Look for your "invisible" files and do what you want. MTP mode is for use with newer PC's. I advice you to use MCS mode all the time because is compatible with any PC (old or new). Good luck!
SOURCE: cant put music on sansa clip
well songs u dl may be protected ok or if uuse windows player 11 to trafer on hd set the settings at mp3 128 bit rate in options then trafer at that not wma those will be protected in players ok thx nick
SOURCE: Sansa Clip with invisible podcast files
The podcats that aren't recognized may be in AAC instead of Mp3 format. Use Media Monkey or some other free software to convert them to mp3 format.
-Tha Mp3 Doctor
SOURCE: how do you download a podcast on the sansa mp3 clip?
www.podcasting4free.com u can download a podcast
SOURCE: placing mp3 podcasts in the podcast folder
Create a folder on your View (in MSC mode) named "PODCAST". DO NOT put it in your MUSIC folder, but in the root directory. Place your Podcasts in there and disconnect your Sansa. After it refreshes you'll find your Podcasts under "Music\Podcasts" on your View :)
