Did you flush the system after changing the filter? Air can cause water to leak if it not flushed after each filter change. It takes about 6 to 7 minutes to get all the air flushed out. I hope that helps...
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
I think you are referring to the water filter alarm. When it first starts coming in, you only notice it when you blink. As time passes, the color becomes more pronounced....If this is right, we'll move on from here, if not, please re-post, and please don't mention the village idiot (me).
The alarm can come on if a high differential pressure is sensed across the filter, or it can come on at pre-programmed times. If the fridge is relatively new, and the quality of the water is good, you can reset the alarm. On my model, I hold down the "ice type" and "child lock" buttons for about 5 seconds. The actual filter is located in the fridge, on the upper right hand side. These filters are somewhat expensive. I say that to say this....You can extend the life of your filter by installing an in-line filter between the wall water valve and the back of the fridge. This will act as a pre-filter for the Samsung filter. They cost usually about a quarter of the cost of the Samsung filters, and are easily replaced. Should you decide to replace your filter, Ebay is a very good source at a less than retail price.
Hope this was what you needed...regards --W/D-- Please feel free to rate this solution!
Hi, this problem IS caused by components that have failed in the rear module! Fact!
There are a few people that sell the kits to repair them on a big auction site.
Hope this helps
bb
