I would like to know the value of this watch as they are in negotiations and I would like to know more
SOURCE: what do the number on the back of the Geneve
There may be three number on the back of a watch.
1) The case number.
2) the movement number.
3) the serial number for the case +watch assembly.
SOURCE: i need to replace the
mcdevito75 Here, Best Bet is to look for a small watch repair shop in your area for this battery change.
SOURCE: i have a geneve quartz
mcdevito75 here, Battery usually lasts 1 year and longer, even if you did change the battery yourself now, you"d forget for a year or even longer next time battery needeed to be changed, I know I did. Add to this you can easily destroy your watch with in-correct handleing. BEST BET, look for a small watch repair shop in your area for this battery change $10--$15.00 and peace of mind.
I wanted to know more or less prejudice because it can enforce this Lusina geneve, the model has small balls, one hour or twelve o'clock, one at 6 o'clock for the minutes and seconds, the case is 10micron gold and features a motion to fhf200 16rubini, can you help thanks
