Question about Pride Go-Go Ultra X 3-Wheel
How do you fix the 7 beep on go go
7 beeps ..have to reset all the time
    Novelist:
  • 60 Answers
Jul 26, 2012 Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Posted on Jul 27, 2012
SOURCE:
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
2 short then 1 short beep
It may indicate error or issue with Video Card.
If you can open and reset VC or try resetting the RAM.
Jul 15, 2015 | ASUS N53SV-XV1 Versatile Entertainment...
CND UV box beeps and turns off
the bulb times needs to be reset. push and hold the reset button until it beeps 3 times and displays 100 and you should be good to go.
Nov 22, 2011 | Creative Nail Design Pro Dial U.v Lamp Cnd...
Reset the "time for service"
hold the clear button without releasing. wait for a beep, and keep holding. a second beep will occur, and it should be reset.
Apr 04, 2011 | 2001 Saab 9-3
I turn on my ps3,tv displays message..invalid format... what can cause this,how to fix it?
Hi there, your display needs resetting back to standard resolution, please follow my guide on how to do this -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
Kenmore electric dryer 66802 timer goes off all the time
Try unplugging it for ten mins or so to reset the chip.
Mar 25, 2010 | Kenmore 62802 Electric Dryer
It is beeping "Error" with 5 beeps
5 beep error means that the waste ink tank is full. You can reset the counter to make it print by doing the following: You have to be exact. If you make a mistake in any of it, just go back to the beginning and start it all over.
1.Unplug the power cord from the printer
2.Hold down BOTH the POWER and RESUME button at the same time and then plug the power cord back in. Keep holding down the buttons until the printer finishes its powering up noises.
3.After the printer is quiet, release the POWER and RESUME buttons. Then hold down the RESUME and CARTRIDGE buttons at the same time with one hand, and press the POWER button with the other. KEEP HOLDING DOWN the RESUME and CARTRIDGE buttons until you hear 2 beeps. They will come quickly together and one beep will be longer than the other. Listen carefully, as they are not very loud.
4. Once you hear the 2 beeps, release both buttons.
5. After both buttons have been released, then press the CARTRIDGE button 15 times. You will hear a beep each time it's pressed.
6. After you finish pressing the cartridge button 15 times, then press the RESUME button one time. The printer will beep and shut off.
7. Turn the printer back on by pressing the POWER button. The printer will work fine now. The waste ink will have been reset to 50% full.
Sep 29, 2009 | Canon BJC-85 InkJet Printer
Ice machine is beeping and not making ice
If you take the front cover off and look on the flip side of it, there should be a chart telling you exactly what the beeps mean. If it is not there or if you can't find it, let me know and I will clarify it for you. It may help to let me know how many times it beeps. It should beep from 1 to 7 times and then repeats. Also on the board, there is a very small reset button. Usually either black or white. You have to look very close, but it should be there. I would not reset it at this time, untill you find out what the beeps are trying to tell you. There is a reason the machine shut down on it's safety device. Good Luck and let me know if I can help
Jun 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Beeps and flashes perform maintnance
Rear the owners manual. It should be referring to an oil change needed but the mileage counter wasn't reset.
Apr 27, 2009 | 2004 Jeep Grand Cherokee
Pride Go-Go Ultra X 3-Wheel Logo
498 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
