MAIN CONTROLLER FOR A STERLING EMERALD MOBILITY SCOOTER
I think i've found it. Go to this website; Click here
http://www.discountscooters.co.uk/extra/pages-productinfo/category-88_90_103/product-1134/scooter-spares-by-make-sunrise-medical-spares-sterling-emerald-sunrise-medical-sterling-emerald-main-controller.html
SOURCE: info neede for mobility scooter
Testimonial: "I had given up hope after mailing several company's asking for the number for the scooter, which was met with no answer, then this morning I cam to mai"
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Testimonial: "thanks for the answer so quick il phone them tomorrow"
SOURCE: i have a sterling 4 mobility scooter... steering
I would think this will be head bearings. These bearings usually loosen rather than tighten up but if they do tighten up the steering will indeed become stiff and probably jerky if the cups that the ball bearings roll in have become a bit notchy. Its an easy fix and should just need loosening off. The bearings are located where the steering tube on the tiller passes through the frame. Its the large nut on the top that needs loosening slightly. There is usually a locking ring that may need lossening aswell. Please be warned that access can sometimes be an issue when trying to get at the headset. If loosening the headset does not cure this problem, there are normally a couple of sealed bearings located within the axle housing (the part where the wheel attaches onto). Its unlikely though that these will be causing your problem. If they are, they will need replacing which requires part of the steering assembly to be dismanted and for safety reasons, may be better left to a dealer. You menion about having new tyres. Was the steering ok before you had these fitted or were they fitted to try and cure this problem? If its the former, it could simply be incorrect tyre type or pressure. Before attempting to correct this problem, its probably a good idea just to lift the front of the scooter off the ground and turn the steering to be sure that the bearings are at fault and not the tyres. I hope I have been some help to you.
Testimonial: "thanks for advice.. "
SOURCE: would like a owners manual for a sterling Elite XS
I couldnt find the 3 wheel version, but the four wheel is in pdf at
http://www.scootamart.com/media/manual/elite-xs-4-mobility-scooter.pdf
hope this helps
Testimonial: "thanks not the exact model but will be of great help"
