SOURCE: error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
If this does not clear the problem the fuser will need replaced.
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
SOURCE: F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
long press Start/copy button If signal is F2 04 , so toner chip is damaged, replace the chip. If F2 40 so developer is Damaged
If F2 64 so try a pogram quic press # int c int then 16 start
