I took gears off and cleaned them along with the shaft and the crossbar bearing . The thing still jumps if I even hold down on the handle .
This is a really old question, but.
Check to verify that the needle bearing is not missing. I is a small round part above the gear on the agitator shaft. Also see how worn the crossbar bushing is. There should only be a minimum of loose play in the shaft moving it side to side.
Make sure the lid assembly is not installed backwards on the kettle casting. The lip part of the kettle is the front or left side, and the cord should come out of the bottom towards the doors/operator side.
