Nokia 6630 Cellular Phone Logo
Posted on Dec 14, 2008
Screen light is not working
I bought a new nokia 6630 screen and within a week, the screen started shaking and now the light is not working, always dim like in the screen saver mode
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
70
Points
Your display card might have gone........ go to a nokiashowroom and they will provide u a beter soln............ if the mobile phone has fallen many times, this problem occurs..........................
46helpful
2answers
How to format nokia 6630 phone momory
hi
to formt the 6630
hold * button + Green Button + 3 Button
and power on
till formatting will appear on the screen
a tricky combination ha ha ha but well it works
Problem for nokia 6630
Update your firmware using Nokia Update Service. May be you have old firmwareand an update often solve most problems.
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
3answers
6630 contact the retailer
chat with me than i will ask u some questions about it and than tell u the solution
Nokia 6630 display screen
my diplay broken so i want to get one.so whear can i get it this
3helpful
Start up failed contact the retailed
If you encounter situation like below on your 6630,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
5. Contact Re-tailer
Do a Full phone formatting on your 6630! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6630 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a nokia logo goes to white or it will blink....
5. After a few minutes when the Full phone formatting completed, your 6630 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip.
1helpful
2answers
Nokia 6630 problem
hi! may be you do not close web and just switch to oher applications. this cause the current open application to run in background which consumes bettery! make sure to close applications properly.here is the tip "press and hold menu button, it will show list of opened application on top left of the screen, goto those applications and close them"
hope it will work!
I see nothing on my nokia 6630 screen..
Try to do a master rest on the phone.
Nokia 6630 display problem
restore ur handset and try else fone requires a service frm nokia care.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
