Question about Jura Capresso C1000 Espresso & Coffee Maker
Changing o-ring on C1000?
I've been able to open up the c1000 as it is out of warranty, is many years old and works well but I think the o-ring is leaking because the output is watery and there is water in the grounds tank. I have replacement o-rings I found on ebay. I got to the area where the brewing chamber and o-ring is visible but could not go further without seeing some pictures or explanation. Has anyone done this before? Any pix?
  • mlross3 Feb 02, 2009
    I'm not sure if this relates to the problem, but when I grind beans for a cup of coffee, the grinds in the container underneath show only a 1/4 to 1/3 as many beans as there should be and the coffee turns out watery.
    I've had my C1000 for years and for many years it worked fine. After a recall, I sent it in. It hasn't worked as well since. I sell the espresso makers at the store where I work. I've been very excited about it until this recent problem. What should I do?
SOURCE:
SOURCE: Capresso C1000 - Coffee is going into the coffee grounds bin rather then
I am having the same problem. I tried every resetting and cleaning in the manual. No luck. Coffee grounds, water everything is going directly to the used grounds bin. Any luck?
Posted on Dec 02, 2007
  • 14 Answers
SOURCE: Steam
Do you descale (de-calcify) your machine on a regular basis? If not you need to try that. Jura has a big square tablet for that and there is also a liquid product called Durgol.
Posted on Aug 03, 2008
EsWorld
  • 1618 Answers
SOURCE: Jura C1000 - All red and green lights blink alternately.
Machine is not getting water.
Posted on Jun 30, 2009
  • 2976 Answers
SOURCE: I have a capresso C1000, and I looking for the
Quite possibly, you can find what you're looking for at an aquarium supply store. They have different types & sizes of tubing.
Posted on Jul 02, 2009
  • 10 Answers
SOURCE: Need an "O" ring Jura Capresso C1000
ebay has them
Posted on Nov 22, 2009
I have check engine diagnostic code c1000e on Nissan Altima 2002. what does the code mean? The vehicle drives and reverses but stuck on D4. The check engine light is on and the OBD2 test shows code c1000...
hi, C1000- Engine; CAN Communication Circuit.
That and maybe water got into a connector. Maybe the AWD connector. Be sure to read the LAN System section in the SM. and the TF transfer section. Sounds like the CAN line going to the AWD clutch got shorted or opened. Problem is the full diagnostics need the Consult 4. I think may be it can help you.
Sep 04, 2010 | 2002 Nissan Altima
Is there a operator manual avilable for the c1000
If it's the old Walker w1000 product, you're in luck. http://shop.clarityproducts.com/products/listing/item3189.asp
If that's not it, check your nameplate and post a comment. C1000 does not come up as a valid Clarity part.
Carl
Jun 06, 2010 | Lands Phones
C1000 lock
i want to use mts connection in haier c1000
Jul 24, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
CHINA MOBIL C1000
i want a china mobil model c1000...and i want to now how much is it!!!plz help me
Aug 04, 2008 | Aladdin Systems Allume Systems Internet...
I had this same problem water going into the grounds disposal chamber, plus all green and red lights flashing. Was told if I could clear the lights to clean the screen and run a tablet cleaning. I was able to clear the lights tried to run the cleaning but it failed again. I have had my machine for over 4 years so instead of sending it back I decided to take it apart. The problem I found is an O-Ring that runs inside of the compression pump chamber failed, if I can find an O-ring that is the same size I believe it will be as good as new.
Dec 01, 2007 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso C1000 Espresso & Coffee Maker Logo
141 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
