Re: What is p-01-538 code means in rz 220ui machine?
P01-538 is Print drum is not locked during operation. ( Drum lock sensor: OFF ) Check the drum release handle has not been forced to the "squeezed" open position.
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
