One of the blades broke on a Hunter fan that is discontinued. Hunter says no other blades are compatible and I need to replace the fan. I would like to purchase black blades for the fan, but the ones recommended by Home Depot did not align with the holes in the fan and would have been visible.
SOURCE: Hunter Ceiling Fans
Unfortunatly that is a common thing with most manufactorers now a days! they are not in the service industry. make it, sell it, dump it, make a new one. and the cycle goes on and on. You may be able to find a repair person who can fix the fans for you at a reasonable cost.
SOURCE: hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
SOURCE: Hampton Bay Cessna Glass Globe Replacement
I don't think King of Fans manufactured your fan, BUT their FAQ says...
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
SOURCE: Fan Parts Hunter Fan Type C Model 25436 No. 017626
Cool Breezes
Cool Breezes carries parts for old fans that Hunter no longer carries parts for
COOL BREEZES
1335 W Campbell RdRichardson, TX 75080
(972) 690-4580push2talk //-->
