Apple MacBook Air  Mac Notebook Logo
Lori Posted on Jul 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan won't stop
2 days ago fan started running all the time, even if I have just one window open with no movement on the page. Before this I could have 10 windows open on 2 screens with movement and the fan would not come on. I checked the activity monitor and it shows that the "DirectoryService" is using 97.3% CPU. THe next largest user is kernel_task with 3.1 %. Please tell me how to fix this. Thanks! L
Kerry Hostetter
Level 2:
Novelist:
  • Expert 97 Answers
  • Posted on Dec 31, 2014
 Kerry Hostetter
Expert
Level 2:
Novelist:
Answers
97
Questions
0
Helped
16654
Points
140
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
2 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on May 21, 2009
SOURCE: Computer has gotten very sluggish for no apparent reason...
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Anonymous
  • 52 Answers
  • Posted on Aug 04, 2011
SOURCE: hai.. can you help me
Start by turning the machine off. Right after hitting the power button hold down the Shift key until the machine has started all the way. See how things work then, if everything is working better you may have problems with some 3rd party program or you have some corruption in the Mac OS.
2helpful
1995 Pontiac Grand AM SE. Heater fan works for weeks then won't go, try a couple hours later then it goes.
It sounds like the brushes on armature for (blower motor ) are worn. Sometime a bad spot on the armature from not being used often and also by being in the engine compartment where it is exposed to condensation. When the brushes stop at that particular spot, the blower will not start spin process unless it draws alot of current that may be why the fuse blew. You can remove the blower and examine or just make the change.
2helpful
2answers
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Windows 7 won't start
If you have a Windows Installation DVD at hand, you can do as below:Step 1. Insert the DVD into your detective computer and reboot; Windows Error RecoveryStep 2. Set language, time and keyboard;Step 3. Click "Repair your computer";Step 4. If you have more than one systems on your computer, choose the one you want to repair;Step 5. Click "Startup Repair" to start restoring your Windows;Step 6. After startup repair is done, you need to take out the DVD and reboot the PC.
More info, visit:windows won't start
1helpful
My LG GC900f's camera suddenly won't work. I last used the camera three days ago and it was great, but when I tried it earlier, it just won't open. Even the apps that need the camera, won&
Don't take it to any normal technician. Go to Authorized service of LG and get it done. It is not any software issue, i think it is hardware problem.
Performance Chip
My 1990 3.0 Toyota 4 runner won't start in the cold
If you have spark and fuel, the next stop would be either the crank position or camshaft position sensors.Either one of those can stop the engine from firing.
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
A couple of weeks ago, my HP Pavilion a706n was working completely fine. Soon enough, the first error appeared. I could use it for a good 5-10 minutes and it would shut off by itself. When I attempted to...
If you have cleaned out the dust with compressed air, then I suggest you look at the processor cooling. Is the fan running up to speed? Is the heat sink tightly in place on the processor? Feel the fins of the processor heat sink when you power it up and if they get hot your processor is most likely over heating and shutting down. If all is well at the processor, check the power supply fan to see if it is running and the only other suggestion is to try another power supply. Dust is your worst enemy in a computer.
2helpful
Dryer will not run
It sounds like you have a bad door switch.
Aug 11, 2009 • Dryers
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
