I put the new battery in my Casio 4735 and can't figure out which terminals I have to touch to restart the watch
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
this video is only an example as to what to do hope this helps you..
http://www.youtube.com/watch?v=ogCz2vjUKVg
SOURCE: restarting after battery change
My watch stops and when i try to wide it again it won't restart. I also do not have a battery in my watch. Please help!
SOURCE: new battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
SOURCE: I am looking for a user manual for casio AMW-705 - 4735
Here you go
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4735&submit.x=28&submit.y=8
If you would like to find manual for any other model you need this link
SOURCE: replaced dead battery on casio
Thank you for contacting FixYa.
Take off white plastic cover so that the only metal cover is seen
2) Notice in upper right corner there is a "golden" pad - tiny one and in the metal cover there is an engraving AC. Use some needle like (conducting) object and connect this pin to metal cover (ground) - this will reset your watch.
Best Regards. Jewel
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general
procedure to switch the ATC 1200 from meters to feet. You can also
switch the ATC 1200 (1170) from C to F. This is very helpful if you
change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the
watch to come up. This is because of a race condition when the watch
gets power. To fix this, look for the AC mark on the inside of the
watch. Under this marking, in a little space to the left, are two
copper pads. Short this out with a small screw driver to get the watch
to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter
abbr for the day is at the top. Also, if you cycle the mode button, it
is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to
the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
