I just cleaned the belt and remove debris from the motor and remove and place back the wirings and boards . and then when i plug it back no more display at the display panel . i double check everything if i got a loose wire or something . but i don't. there is current running because i see the led lights on the board . pls help me.
1_ CPU is SYSCON, is the unit control electronic,that sen all electronical signal to the electronic of equipment.
2) tight every wires connector very well and clean it
3) Run the software calibration for diagnose, troubleshooting , fix it
4) However you must calibrate the REED swith, see the diagram, clean it, and tigh the wires connector very well, exchange the batteries by new ones and clean the contacts cleaner 5) tight the ribbon cables from keypads switch +tight the display board connector vs lower board and proof again.
God bless you
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
SOURCE: I have a Lifefitness Treadmill model TR 9100,
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
