Engine will not turn over.
Lots of possibilities for a no start condition. Do you hear any type of noise (such as clicking, etc) when trying to start the car? If not, recheck all connections and fuses under the hood as well as inside the car. Is this an auto or manual transmission? If its manual check the switch on the clutch. It its auto it could be the neutral safety switch.
SOURCE: the check engine light came on and the RPM needle
If depends on the milage of the car, some lights come on after 100,000 miles just to remind you that maintanace is require but is good idea to run the car thru a scanner to be sure.
SOURCE: i have a 2004 kia
That usually means the steering wheel is lock and you must turn the steering wheel either left or right firmly and try turning the ignition on at the same time, if this fails, the tumblers in the ignition lock cylinder are seized and must be replaced. but make sure you work that steering wheel left and right first (firmly).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: The check engine light just came on my Kia Amanti
that means the computer detected a problem and need scan. take it to an autopart store and they will scan it for for free and tell you whats the code. Good luck
SOURCE: I have a 2004 Kia Amanti with a "Check Engine"
P0302 is a cylinder misfire detected in cylinder #2. it can be caused by Bad spark plug,failed plug wire or coil pack, or failed injector. these are the most common reasons in most likely order.
