Sony hdr-hc7 image jitters when angle is up
Sony service centre can re-set the firmware to change the reactive feedback loop of the vertical direction of the optical stabilizer (turning the camera on its side will usually stop the vibration). See:
https://vimeo.com/181229317
Re-setting the firmware rarely works for very long.
I can fix this by taking the lens system apart and repairing the root cause of this.
SOURCE: sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
The lens cover mechanism in these cameras is susceptible to debris and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com
