Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Steff Studer Posted on Mar 13, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi Wd-52525 HDTV Stutis light constant red
I am wondering what might be wrong with our 52' Mitsubishi WD-52525 flat screen HDTV. When you go to turn on the tv the timer light blinks green for about a minute and then the tv trys to turn on, I heard the sound, then it fails and the status light turn a constant red. We have had the tv a little over 14 months and have not replaced the lamp. However, the lamp light is not red and we have never received a warning message on the tv about the lamp being about to fail. How would one know if the lamp needs to be replaced? Additionally, we cleaned the filter, and tried a system reset over the phone with Mitsubishi to no avail. We would like to fix this ourselves rather than have to call someone to repair it. Any idea what the problem might be? All advice is welcome and greatly appreciated.
  • Steff Studer Mar 14, 2007
    I read a few other posts on these tv's after posting this message. Anyways, after hearing that you could hit the device and menu buttons at the same time and a code would be produced in the falses from the green lights, which can be used to diagnose the problem. Well I tried it and my tv is giving out a 1-3 code. What does this mean?
  • tjgitto May 11, 2010
    have a yellow light blinking on status tv will not come
Anonymous
Level 3:
  • Master 944 Answers
  • Posted on Mar 14, 2007
Anonymous
Master
Level 3:
Answers
944
Questions
Helped
786863
Points
2417
Here is the link to the manual if you need it; http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf page 97 states that the lamp is the problem -(the flashing green just means startup - page 11) 14 months sounds about right for a new lamp if you use it a lot - that would be an average of 5&1/2 hours a day if the lamp went to 4000 hrs - although these lamps are more dependable than normal lamps, they can still fail anytime especially if they have been touched on the glass by accident while installing or cleaning, or if the tv is often switched on and off. The fact that there was no message on screen may mean that the lamp has not gone past the warning trigger number of hours - sorry i haven't found what that value is. page 95&96 gives all instructions how to replace lamps and where to get spares - if the price seems bad then search around - prices often vary a lot on these lamps. It is a little disappointing that mitsubishi where not able to diagnose this - please let them know that their technical service is poor in the hope that they try harder. I hope this helps :) Hope this helps :)
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Replaced bulb in Mitsubishi WD-52525 and it still does not work
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
3helpful
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
1helpful
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
No signal, blue screen
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
