Motorola Mobility CLIQ Cell Phone Logo
A
Anonymous Posted on Dec 14, 2017
Mb508 cant open apn to unlock phone for internet
I called simple mobile the phone was turned on it works but i cannot access the internet they tried to help but to no avail. I was looking at the name where it should say simple mobile it said Tmobile.us i tried to access through setting a new apn but that screen has no menu options to put a new one in please help
Life wireless apn settings for at&t kyocera duraforce e6560
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
2answers
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
Good Afternoon..... I cant receive or send pictures what is the APN code for SVP G13 watch phone
An Access Point Name (APN) is the name of a gateway between a GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
For AT&T
Programming non AT devices with the correct APN and MMS data settings AT...
For Tmobile.
Mobile apn settings Step by Step Configuration
Tmobile samsung dart i cant access web only trough wifi does it work
Probably the data is off, try going to Settings, More, Mobile Network, and check the Data Enable box. If you still can't get internet by enabling data, then your APN must be off. If you are still with T-Mobile, then go to Settings, More, Mobile Network, Access Point Names or APN. From here you can see which Access Point is check, troubleshoot by checking one of T-Mobile's APN and trying to use the internet without Wi-Fi.
No internet connection T mobile (ex voda phone)
Seeing your Phone companies can't help with OTA internet settings (by the way, OTA means Over The Air) for you to configure your phone, you may have to go the Manually configure your phone for internet route.
To do this, go to your SIM card network service provider website and download Manual settings for Internet access.
Open settings in your phone and navigate to either Network/Mobile Networks/APNs, etc and Manually configure your phone.
When completed, select Use as default data/internet access
Internet and text message setingss for simple mobile
Have you tried?
  1. Pull down the notifications screen & tap on Settings
  2. Tap on Mobile Data (some phones say "more"
  3. Tap Mobile Networks (some phones have "Access Point Names" here)
  4. Tap Access Point Names
  5. Press the menu button
  6. Select New APN
    • Name:SIMPLE Mobile
    • APN: simple
    • Proxy:<Not set>
    • Port:<Not set>
    • Username:<Not set>
    • Password:<Not set>
    • Server:<Not set>
    • MMSC:http://smpl.mms.msg.eng.tmobile.com/mms/wapenc
    • MMS Proxy:<Not set>
    • MMS Port:<Not set>
    • MCC: 310
    • MNC: 260
    • APN Type: default,supl,mms,admin
    • If no APN settings are present, a restore to factory default settings may be required.
  7. Select Menu and Save
  8. Go back one screen to the APN list and tap on the dot to Enable the SIMPLE Mobile APN
  9. Restart phone & you're set!
My YouTube
Live Tech Support
Make your cell payments here
2helpful
2answers
I can't receive MMS on my Sharp Stx-2 (unlocked for tmobile), but I can send MMS. What are the right messaging settings so I can receive MMS?
Make sure you have your mobile data turned on. On some phone models, when sending an MMS, the phone will automatically enable it until it is sent. In order to receive one, you may have to enable your mobile data from the phone's menu. Since you're unlocked on T-Mobile, it's possible that your phone supports sending MMS over standard networks, but not receiving, in which case your phone's antenna is not compatible with T-Mobile's network frequency.
1helpful
Im using htc hd2 t8585 model mobile since last 6 months but it was not getting connect to the internet even i have net balance
first call customer care of your mobile operator and ask them apn for windows mobile, just note the apn (access point name). next go to settings, open connections, again open connection from sub menu go to add new connection, you can put operator name in my connection column and in the below column select cellular line gprs, click next, enter access point name, enter next leave user name password and domain blank, click finish, do a soft reset and try opening internet explorer, if this dosent work delete all other setting and do setting again,
and if still it dosent work you need to perform a hard reset and do setting again it will work 100%.
beware if you do hard reset all you data on phone ,like contacts will be lost so do a back up before attempting hard reset
25helpful
17answers
Enabling Edge on Unlocked iPhone
On an unlocked iphone for the T-mobile carrier you need to add the full internet package to use the internet.
The apn is internet2.voicestream.com or internet3.voicestream.com if you have VPN internet.
Wap.voicestream.com may work, but it is not for sure, and might not give you the full internet. Only wap pages which are different than html.
To add this you go to settings>general settings>network>cellular data network or edge and then put the apn in the apn field. Make sure data roaming is turned on, and 3g is turned off.
Do not put in a user name and password, and go back to the main screen. Make sure your wifi is turned all the way off, not just disconnected.
Try to browse. If this fails you may need to reset the network settings. To do this, go to settings>general settings>reset>reset network settings. DO NOT reset anything else or it may re-lock your phone. Then when the phone resets go back and input the apn again, and turn off wifi.
Happy browsing!
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
