Southern Telecom Emerson Bluetooth Headset - Magenta Wireless Headset Logo
Posted on Dec 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emerson bluetooth bluetooth: i am tryin 2 add my emerson bluetooth and i put the passcode 0000 in but it didnt work wat should i do
  • Anonymous May 11, 2009
    the point is that the passcode 0000 does not work. following all the proper steps, the problem is the code is mismatched. 1234 does not work either.
Anonymous
Level 3:
  • Master 679 Answers
  • Posted on Jan 31, 2009
Anonymous
Master
Level 3:
Answers
679
Questions
0
Helped
348623
Points
1860
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (Serched bluetooth device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
1helpful
13helpful
2answers
Can not pai emerson em227 bluetooth headset with iPhone.
Just got off the phone with Southern Telecom (Emerson's supplier)
If you return the unit with a note telling them you need the new model for an I-Phone they will send you a new one.
Southern Telecom
14C 53rd St.
Brooklyn NY 11232
11helpful
2answers
Emerson em227 wont pair
With your phone closed press and hold the center button on the bluetooth until it starts blinking blue and red the open your phone and go to blue tooth> ad new device> then it will go to pairing then auto pairing and that should do it
4helpful
I cannot get my emerson em227 bluetooth to connect with my iPhone. It pairs and the bluetooth blinks blue but it will not connect. I use the ''0000'' passcode and it says invalid passcode.
This happened to me with my iPhone. I called Emerson and they are aware of the problem. I sent the headset back and they are going to replace it with one that works with the iphone. Their number is 877-768-8483 in NY.
2helpful
Passcode needed for Emerson EM225/226
Try setting different visibility settings on your phone (i.e. Visible, Hidden, and Temporary are the three for Bluetooth on my Palm Centro.) It did not work on the hidden setting, even though the Centro could detect the headset, but when I switched it to Visible, it connected to it.
You have the right passcode, because, incidentally, I was searching for the passcode to the headset (I thought it would be an successive sequence like 1234, which did not work), and 0000 worked for the EM226 I own.
If it does not work I recommend that you contact either Samsung or Emerson (Samsung being the one who will be able to most help you).
6helpful
3answers
PASSCODE
hi have motorola h700 bluetooth device but i forget my passcode how do i reset it again i tried many passcode like 0000, 1234, 1111 ,2222, 3333,4444,5555,6666,7777,8888,9999, but its not connecting wat do i do nw.. plz solve my problem.... my email address is [email protected]
2answers
39helpful
6answers
Bluetooth passcode
All bluetooth have a default passcode of 0000
23helpful
5answers
Forgotten bluetooth passcode
CupidsEnemy - passcode 0000 try that...it will work
Guest - just connect and when ask for passcode type 0000
Top Southern Telecom Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Southern Telecom Radio Communication Expert? Answer questions, earn points and help others
