I had just started mowing and the mower engine died. I was trimming while I was letting it cool and kicked up a spring, 5/8" diameter x 2" long, at the edge of the grass. Further attempts to start the mower failed. I checked the gas, oil, and air filter. I don't have a spark plug wrench so wasn't able to check that. I believe the spring is from somewhere in the mower as it is very clean - the mower is in it's second season. Any suggestions?
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
SOURCE: Its starts but will cut off
The problem you are having is due to dirt and gunk in the carbeurator. Spray a carbeurator cleaner into the air chamber [remove the air filter] and run it a couple of times then let it sit for two hours while the carbeurator cleaner does its job of dissolving any debris. Then start it up. IF this does it, great, if not repeat the cleaning technique.
If all of this doesn't do it, then the carbeurator will have to be removed and either replaced or rebuilt.
SOURCE: Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
SOURCE: I have a Troy-Bilt Mower - Model 834. It has a
sounds like the throttle cable has slipped on the side of the engine if they dont pull the choke all the way on they wont start too well. one way to find out is take your air cleaner and outer cover off so you can see in the front of the carby the put your throttle on start/choke position the choke butterfly should be closed if not check your cable.
SOURCE: My Troy Bilt Self Prop. Z-start won't keep running...
There may be a cracked fuel line, cracked primer bulb, loose carburator, dirt/trash in the carb....it sounds like a fuel supply problem. Hard to tell with out hands on.
