Bed is wired 1 phase need to rewire to 3 phase
SOURCE: need wireing diagram to change 72 nova over to hei distributor
Hey , just take the positive wire from the coil you are removing and feed it to the + terminal on the HEI dist. cap.the other terminal under there is for your tachometer. If you are mounting a master kill switch in the bumper for drag racing- attatch the kill wire to the tach terminal also.
Thats it you just plug the three wire pigtail from the dist. base(pickup) to the cap and you are off.
Remember firing order is 18436572 in a clockwise direction. to find #1 remove #1 plug and have someone"bump" the engine over while holding your finger over the hole-carefull. then line up the slotted mark on the crank pulley with the big notch on the timing indicator. Good luck
SOURCE: need a wiring diagram for a 99 ford transit
please visit www.2carpros.com ........you will get the your wiring diagram
SOURCE: tail light wiring connectors and wiring diagram
A test light checking each connector would be faster and easier to do. Maybe somebody may have a illustration for you but by far a simple test light is all you need with a helper turning on the different lights as you check them out and writing all your findings down
SOURCE: i need a free wiring diagram for a 1998 chevy
Black/white is A,........ Green is B ......and Gray is C
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to factory installed systems not add
on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
