When I turn on the power button it blinks green a few time then starts blinking red 2 blinks at a time, and the bulb light starts flashing red 2 blinks at a time.
Panasonic PT-44LCX65
Hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
1. Tighten the screw of the Lamp Cover.
2. If still NG, replace the Cover SW (SW2911) on the Cover Switch C.B.A.
3. If still NG, replace the TV unit (Main C.B.A.).
these are the fualts for the 2 times on the temp light
these are fualts for 2 times on the lamp light
temp light Abnormal Temperature
(Thermistor 1 C.B.A.) flashes twice every 5 seconds
lamp light Ballast Error (abnormal Lamp voltage) flashes twice every 5 seconds
sorry i didnt know what light you meant these are for the other light codes fualts
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display as shown in Fig. 5-
1 appears and the LAMP LED goes out.
the manual says if its the lamp couver it will blink orange twice. But my tv blinks Red twice on the power button and on the bulb button. Thank you for your help
Can you tell me how to reset the lamp timer? I have no remote for the tv.
Thank you
Tony
2 blinks
TV wont turn on red light just flashes
TV turns off after turning it on then lcd Light blinks 2 times first then blinks once every 3 seconds after.
TV Froze. After turning it off, it wouldn't come back on. Now red light blinking.
my TV 32S310 IS PROBLEM IS EIGHT TIME RED BLINKING
turn it on works, connect cable works few minutes then screen goes blank
