First of all, I apologize for the wording on how this question is asked. We have a Norstar M7208 phone that rings for global rings (example: if you call any of our 32 lines, the phone will ring) and if you call the extension/direct number (for this single phone) it will ring with a double ring. I want to disable the global so it stops acting as a hub, and just as a satellite.
This is tech side of programming and not Admin, if you don't know config password or how to program then call a tech.
If you do know then:
First find out what line #, do F*0 then press the button and note the full number on the display.
i.e. Line 5 in programming is Line 005, 025 or 031 depending on software version.
Sets/LineAccess/LineAssignment/Show line ***/Change to Appear Only or Not Assigned.
Sets/LineAccess/LineAssignment/ShowLine -> Regardless if it is set to AppearOnly/Unassigned/RingOnly/Appear&Ring - the phone will still ring. I became discouraged and looked up the extention of the phone, within the extention if I set the ringer within and call the global number that is the ringer used - but if I call the extention, a different ringer is from a local phone, a different extention is used. Break down. 254 is the phone extention. 147 is the extention with the trunk line 1777 directed to it. Button1 Line1 on the set phone, extention 254, has 145:1777 bound. How do I go about removing the re-dirrection of line 145 to extention 254?
SOURCE: My Norstar M7208 phone wont ring. We've moved
Is set relocation on?
If not then probably what has happened is that the new station port does not have ringing programming of the old port.
if you know how to do this go into riging programming of the set and activate it
SOURCE: Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
SOURCE: Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
