I went to Olymbus website to find the driver for the FE-280 Digital camera and it states, no software availble at this time.
They show the camera on the website and I know there is a driver for it, but they are not supplying the consumer with it. Bad choice for Olympus.
I have given you some information and links below:
http://www.olympusamerica.com/files/FE-280%20Instruction%20Manual.pdf
This is the manual for your camera.
Go page 45 at the very bottom. Using a New Card
The FE-280 does not recognize my memory card. What can I do?
First, refer to the
xD-Picture Card™ Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
The FE-280 may not recognize non-Olympus brand media or a card that has been formatted on another device, such as a card reader or personal computer. As a general rule, xD-Picture Card media should only be formatted in the camera. Card readers should only be used to
copy files from the memory card to an external device.
You may be able to use the card if you format it in the camera.
Warning: Formatting a media card will delete all content on the card.
When I put an xD-Picture Card™ flash memory card into my camera and turn it on, I get a “Card Error” message. What can I do?
This message occurs when the camera is unable to recognize the memory card or when an attempt to format a card fails.
If you see this message after inserting a brand new card, refer to the
xD-Picture Card Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
If the card is supported, it may need to be cleaned. Wipe the gold contacts of the card with alcohol using a soft cloth or tissue. When the contacts are dry, insert the card and turn the camera on.
If the Card Error message still appears, remove the card and insert a different supported card into the camera. If the camera reads the second card, then the camera is working properly and the problem lies with the original card.
If you receive this error message after a failed attempt to format the memory card, the card may be defective. For assistance, contact Olympus’ Customer Service and Repair Center using any of the following methods:
Phone: 800-622-6372
http://www.olympusamerica.com/cpg_section/OM_UpdateSoftware.asp
This is about updating the olympus Master Software.
If I can do anything else for you let me know
