A scratch like a vertical rugby ball on screen which is noticable when tv is on or off?
SOURCE: plasma tv scratch
Things You’ll Need:
* Television screen cleaning products
* Cleaning schedule
* Microfiber cleaning cloth
Clean Your HDTV Screen Properly
Step1
Read the warning labels on all your household cleaning products. Even
glass cleaners might not be suitable for use on an HDTV screen, so
check the manufacturer's warnings before you apply anything to the
screen.
Step2
Keep chemical cleaners away from your HDTV on cleaning day. The harsh
chemicals found in most common cleaning products will actually cause
more harm than good.
Step3
Leave liquid cleaners under your sink when cleaning your HDTV screen. A
liquid cleaner, whether it be water or a chemical cleaner, will drip
down the screen and work its way into the interior of the TV, causing
damage to your HDTV. You will be able to easily recognize when this
happens, because your screen will develop smudges.
Step4
Use a cloth to clean the HDTV screen. Ideally, you should use a cloth
that is recommended for HDTV screens, computer screens and other
electronics. The word "microfiber" may be imprinted on the packaging.
Step5
Wet the microfiber cloth slightly. Just a hint of dampness is all you
need. If water runs out of the cloth, then it's too wet and will cause
smudges.
Step6
Develop a regular cleaning schedule for your HDTV screen. If you dust
the screen daily, or at least several times a week, with your
microfiber cloth, no other maintenance should be necessary. Not only
will frequent cleanings make caring for your HDTV easier, but they will
also enhance your viewing experience.
Step7
Prevent messes by asking family members and guests not to touch the
television screen. You should also try to make sure children with
sticky fingers do not come in contact with the screen.
Step8
Use a high-end cleaning product if you feel that regular dusting is not
sufficient. Top-of-the-line television cleaning products are ideal for
use on all HDTV screens, plasma screens, projectors and are safe to use
around children and animals.
SOURCE: plasma scratch
Try this link
http://www.ehow.com/how_2076392_clean-plasma-tv-screen.html
Hope it will be of some help
SOURCE: Scratch on plasma screen
You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
SOURCE: removing scratches on plasma screen
try calling a glass store and i believe they do have a polish that will take them out but be very careful that glass will break
VERY easy
SOURCE: I need to repair a scratch on my panasonic 42
It is glass but it may have a treatment on the surface, typically cleaning it will help. Buff with a microfiber cloth.
