Is there a way to set wallpaper as my flash drive background? When I plugged in my flash drive to any PC, the wallpaper should be visible,
First you need to create a desktop.ini file in your flash
drive. Open Notepad and click Save as. Then set file name to desktop.ini and change Save as type to
All files. Click Save as. Place your wallpaper in the flash drive. It should be a
".jpg" file Open desktop.ini file from your flash drive. Copy and paste
below code to it. Last line of the code, you can see
"IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper
name. [ExtShellFolderViews] {BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC} [{BE098140-A513-11D0-A3A4-00C04FD706EC}] Attributes=1 IconArea_Image=wallpaper.jpg Save your file. Unplugged the flash drive from PC and plug
it again. That's it. If you need more information Visit SmartUSB.net Add wallpaper to your flash drive background http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html Change your flash
drive icon http://www.smartusb.net/p/change-flash-drive-icon.html Insert symbols to your flash drive label http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html Hide a file or folder in your flash drive http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html Change font color in your flash drive http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
I found it, from another web site. SmartUSB.net.
It explains step by step, how to change
font color in a flash drive.
Show your colors to your brother.
Change your flash
drive icon
There is a method to do it. But not simple. But following few steps you can do it.
Visit SmartUSB.net.
It explains step by step, how to insert
symbols to flash drive label.
I think you will also like these things,
Change your flash drive icon
The easiest method is change file to a hidden file.
Right click on the file - properties - tick on hidden
There is an advanced method, change file to a hidden file
and as well as system file using MS-Dos.
I refer you to SmartUSB.net. It is a good source for flash
drive users.
Change your flash
drive icon
Change the icon of a flash drive or any kind of removable
disk which use to store data, is very easy.
Just try this,
1.
Open Notepad and copy and paste below 2 lines to
it.
[autorun]
Icon=logo.ico
2.
Save it as
autorun.inf to your flash drive
Before to click Save as... change Save as type to All Files
3.
Then copy and paste your Icon file to flash
drive
4.
Rename it to logo.ico
5.
Remove your flash drive from the PC and plug
again
You will see your flash drive with a custom icon
For more and clear information visit
