Acer Aspire M1201 Athlon X2 320 Gb  PC Desktop Logo
A
Anonymous Posted on Jun 20, 2017
When I try to power up my acer aspire M1201 the power button isn't responding
I turned off my Acer computer the other night ....properly through Start shutdown because it looked as it there might be a storm. It shut down okay but when I tried to turn it back on last night the power button doesn't respond. It usually turns blue when power is on. I checked my surge protected power bar and turned it off and on, I plugged directly into wall outlet, I tried a different power cord...........nothing. What could be wrong please?
richie46
Level 3:
Top Expert:
  • Acer Master 12,962 Answers
  • Posted on Jun 20, 2017
richie46
Acer Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945903
Points
58151
Check to make sure that power is reaching the power supply of your unit. If it is and still does not work, then the issue is with the supply that needs replacement. Common malady.
5 Related Answers
A
Anonymous
  • Posted on Jul 24, 2008
SOURCE: acer aspire 5715z/5315, turned laptop
back up your important file,through accessing safe mode.pres f8 so that you can go to safe mode.then get the important file.
reinstall your OS so that it can run normally.
enjoy...............
Anonymous
  • 14 Answers
  • Posted on Dec 31, 2008
SOURCE: ACER power 1000 has no power at all
change the power supply, if still nothing then motherboard might be gone
Anonymous
  • 166 Answers
  • Posted on Aug 23, 2009
SOURCE: we have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Anonymous
  • 707 Answers
  • Posted on Oct 15, 2010
SOURCE: My Acer Aspire x1200 desktop
Have you by chance downloaded a new Service Pack for Windows?
Try booting into safe mode and doing a System Restore (if possible), if not try taking out your RAM Module(s) and re-seating them (it). If more than one try re-seating each one separately. One bad module could cause erratic behavior.
mastericpr08
Gustavo Ortiz
  • 637 Answers
  • Posted on Jan 31, 2011
SOURCE: Acer aspire x1200 - Will
Can be two situation,replace the video card or replace the memory card
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
1helpful
4answers
I need a wiring diagram for an acer aspire m1610. I replaced the motherboard and now it powers on but the button doesnt power it off and im getting no signal to my screen, plz help
Doesnt power off:
I think your front-panel cables arent connected properly. (the picture might be wrong, because not all front-panels are the same)
No video signal:
The problem isn't with your monitor, it's wth your video card, motherboard, CPU or power supply. Do you get the single beep at startup?
Acer aspire m1201 not booting up - I powered it down normally and moved it to another location. I have opened up the tower and I have reseated anything that I could and pushed on other cords that were...
Please check to see that the LED light on the motherboard is lighting up. Also, if the BIOS appears on the monitor, please make sure that the hard drives are properly connected and that you can hear then spinning and/or see the Hard Drive LED light up. It sounds as if your motherboard is receiving power, but something else is not. Please also make sure that your processor's heat sink is properly seated and secure.
Acer Aspire M1201: We need to find out what 2 short quick beeps signify. The unit will turn on but no video. We have already tried replacing the video card and ram and still same issue. Please help.
Have you tried connecting an external monitor and see if that one would work? Also, are you hearing any startup sound when you turn on the computer? If there is, and there is a good display on an external monitor, then it is the LCD that is causing the problem.
1helpful
3answers
Looking for manual for acer aspire m1201. its on complete lock up powers up and thats it
Please go thru this link to find the manual.
http://support.acer.com/us/en/acerpanam/desktop/0000/Acer/AspireM1200/AspireM1200nv.shtml?Team=%2Fus%2Fen%2Facerpanam%2Fdesktop%2F0000%2FAcer%2FAspireM1200%2FAspireM1200nv.shtml
My acer aspire M1201 completely froze up , keyboard or mouse dont work. Come up to a static screen that says "acer". Wont go any further.
Perhaps you can try pulling the battery, waiting a couple of minutes and then putting it back in/retrying the boot.
jobst consulting
2helpful
Replace the optical drive on Acer Aspire m1201
based on the images i've looked on for the Aspire m1201, you don't need to remove the front panel in order to remove the optical drive. if there are screws holding the drive in, remove them and then slide the drive forward. if its held in by sliding latches and not screws, then slide then in which ever direction necessary and then push the drive forward to take it out.
1helpful
Not found winxp driver Acer Aspire M1201
http://203.150.225.245/UpAndDownLoad%201/PC/drivers/Aspire%20M1200,M1201,M3200,M3210,M5200,M5201/WLAN.zip
Wireless Lan Driver, if that what you are looking for.. or...
http://komku.blogspot.com/2008/12/aspire-m1200-m1201-m3200-m3201-m5200.html
Just scroll down for a list of drivers for that Acer.....
hope this helps! :)
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
