I was copying a movie clip to my flash memory, when it was over it said "this devise is write protected" the movie clip was copied properly and working then i copied the movie out of the flash memory and it was the only thing in it. after that the flash was still used the space was used but there is nothing in it so i tried formatting it it said" this disk is write protected" and i can't copy file's into the flash i tried the low level formatting tool but it didn't work ! please Help and thank you .
SOURCE: how to remove write protected memory card
when i attach the card reader with system and when i store the software or any thing in memory card then msg show that(cannot copy because write protected error)
SOURCE: USB Write Protection
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
SOURCE: Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
SOURCE: to remove write protection of my memory card for nokia 6630
we have dissame phone model... and i think i can help you ... get the memory card and a card reader and connect it to a computer then format .....in the computer you can format it
SOURCE: i cannot copy files from computer to my phone memory card
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
