Nortel 1230 IP Phone NTYS20 Logo
Sarah Webster Posted on Jul 25, 2012
Does anyone know how to programme speed dials on this phone?
1helpful
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
How to program the programmable keys to an external number
The programmable key has to be an SPD button, you then enter the speed Dial entry number. To do this go to Youtube and follow the training video which I have loaded for you, this explains MMC 722, you must have that specific phone number in the speed dial directory, again this can be found at Youtube search 'abbeytel'
4helpful
2answers
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
4helpful
Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Need manual for SBC Freedom Phone Model HAC FC2548
to programme speed dial just go to contact on your phone menu and select the conatct you want to speed dial and assign speed dialing number for the person or you type any number on your phone and press the harsh key like this (10#) and it will bring out the number assign to that spedd dial
3helpful
2answers
Setting the speed dial numbers
Dial Feature *4
Enter the speed dial code (71-94)
Press a line button or a pool button
Dial the phone number desired
Press hold or OK to finish
Programing speed dial
If you have a newer Toshiba phone system you will press Intercom #66 to get into speed dial. Once you in speed dial numbers 10-99 will be station speed dials and 100-999 will be the system speed dials. I included a website with manuals below. Hope this helps.
http://www.wedophones.com/ToshibaManualsLead.htm
1helpful
Cable & Wireless CWB200H Speed Dial
1. lift the handset.
2.press store
3. pin in number to be phoned.
4. press store
5. press one of quick dial buttons
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Top Nortel Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
