When I insert a pair of headphones into the headphone jack the display on the HK just flickers video 1 (or whatever input) and HE and the headphones don't work. It's supposed to slide the word HEADPHONES across the screen and then work.....
I've tried with different headphones, same thing.... Please help!
Cheers
Troy
Thanks Jacob. I've tried 2 different headphone 6.3mm jacks so it's not the headphones that are the problem it's the AVR. I've reset the AVR but still no go.Thanks Jacob. I've tried 2 different headphone 6.3mm jacks so it's not the headphones that are the problem it's the AVR. I've reset the AVR but still no go.
You can't post conmments that contain an email address.
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Most DVD's have line-level outputs which will NOT drive headphones. You need to run the audio line outputs, which are usually RCA jacks to jacks on an amplifier and then plug the headphomes into that. An inexpensive source for an amplifier is OFTEN at thrift shops. Run the pair of cables into jacks that would likely be labeled TAPE INPUT for example. FInd one that does have a headphone output jack on the front.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall www.onecall.com
twitter.com/onecalldotcom
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
