My config is siteA-----ASA______DLINK----SiteB VPN.vpn is up and working but site B can use remote desktop on site A but reverse is not true.I am on site A and I want to use remote desktop on my clients on site B.I opened fort from virtual server in Dlink but it didn't help.pls help
SOURCE: DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
SOURCE: VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
SOURCE: HI. I have problem with
Go to the router site by using 192.168.0.1 or 192.168.1.0 or 192.168.1.1 password is admin and leave the rest blank. Unless you have already set a password. You can configure your router settings there. Thanks for using FixYa! John
