Just bought an old white model 265 sewing machine and after I oiled it, it did a perfect staight stitch. So I thought I'd try the zig zag feature...I didn't have the manual so I tried the logical settings. There are 2 little buttons and a slide lever to control the stitch width. something must have broken inside because the slider is not attached to anything and I can't get the machine to just do a straight stitch again. and the zig zag stich is very irregular (a mix of straight and zig zag. What's my solution? Barb
My suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching
mode and in that give the straight mode the problem will be solved
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
SOURCE: Bernina 930 won't zig zag
You will need to remove the top cover. 2 screws one of which is under the bobbinwinder lid. They only turn a half turn to release. After opening the top cover and if you watch what goes on inside from the top, move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Hope I helped.
