If your dimmer smells burned, it probably is.
As general rule, there are no repair parts for in-wall electrical devices since they are contained inside sealed plastic shell to prevent fires.
The burning smell was high heat and melting that would have caused a fire if in-wall electrical devices were sold without safeguards.
Replace dimmer.
Be sure to check watt rating on side of old and new dimmers to match correct load rating.
Take out of son's allowance, and make the future electrical genius help read small print on instructions and install new device.
Turn power off to replace device.
Use non-contact voltage tester to check that power is off.
http://waterheatertimer.org/How-to-select-right-wire-nut.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I installed the dimmer 600 w and now the light
are you using one of those florescent bulbs? They generally can't be dimmed.
