Is it possible to put a security code on to keep the fax machine from printing but still receive faxes and then put in another code in the morning to allow printing
Ohio IT 1040 I-File is a convenient way to file your Ohio
individual income tax return. But we recognize that it may seem
daunting at first...so we designed this page to help.
Below are the most-commonly asked questions about Ohio
I-File, followed by an important note regarding the registration
process. Finally, there is a link to the complete list of I-File
frequently asked questions.
We hope you enjoy your fast, free, and secure filing experience.
Unable to register: If you are
filing an Ohio income tax return for the first time or if you are unable
to register, you will be required to fax your social security card or
IRS ITIN assignment letter and at least one additional piece of
identification which must include your date of birth. Acceptable
identification includes a valid driver's license, state issued
identification card, U.S. passport or military ID (copy of both front
and back sides required). To initiate the registration process, fax your
request and necessary information to our online registration group at
1-206-600-6113. If you have further questions about the registration
process, Email Us
or call us at 1-800-282-1780. In the event we need to contact you
please include your email address and/or a daytime telephone number.
Allow up to 24 hours before attempting to register after submitting your
information.
Note: Due to security reasons
we cannot change or add your name, social security number or date of
birth from a telephone call. You must fax the required information to
the number listed above.
For a complete look at Ohio I-File information we recommend you read the entire list of before you get started.
SOURCE: Intellifax 4100 won't receive faxes
probably you not properly install a line cord,try to check.check it and this is 100%.if you still have problem try to conect the telephone on telephone line cord aand check the line is ok.
SOURCE: Trouble faxing and receiving fax from "Brother 575".
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
Hopefully this will work for you.
Dave Grannas
SOURCE: display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
SOURCE: Need to reprint previous fax.
you can't. check the journal for the last receive transaction fax number. send a request for re-transmit.
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Press (Fax) on the control panel.
Press Menu until Advanced Fax appear.
Press the left/right arrow until Secure Receive appear and press OK.
Press the left/right arrow until On appear and press OK.
Enter a four-digit password you want to use and press OK.
You can activate secure receiving mode without setting a password, but cannot protect your faxes.
Re-enter the password to confirm it and press OK.
Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
Press the left/right arrow until Print appear and press OK.
Enter the four-digit password and press OK.
The machine prints all of the faxes stored in memory.
Press the left/right arrow until Off appear and press OK.
The mode is deactivated and the machine prints all faxes stored in memory.
Press Stop/Clear to return to ready mode."
To prevent people from accessing faxes that are sent to us over night is there a way to prevent the faxes from printing until someone comes in the next morning? Could we set up a security code to "lock" the fax machine and then enter a code to unlock and print what is in memory?
