I need instructions on how to pair it with my home theater
You can also plug in your Keyboard/mouse (any usb type keyboard and/or mouse will work with a PlayStation 3). That will allow you to navigate the PS3 XMB Menu, as follows:
1) Prepare the BD Controller.
2) Go to: (Settings) > (Accessory Settings)...
3) Select [Register BD Remote Control].
4) Follow the on-screen instructions to register the BD remote control.
When the registration, or pairing, is complete, your system will assign a controller number to the remote.
Hints
Plug in any usb/usb-wireless Keyboard / Mouse. (Plug & Play) Use that to Navigate the XMB PS3 Menu (the ps3 menu) as follows:
1. - Prepare the BD remote control.
2. - Select (Settings) > (Accessory Settings).
3. - Select [Register BD Remote Control].
4. - Follow the on-screen instructions to register the BD remote control.
Hints:
You can register only one BD remote control at a time. If you register another BD remote control, you will overwrite information on the currently registered device.
After you reach the maximum of seven active wireless controllers, you cannot register or use a BD remote control.
stering the BD remote control with another PS3 system will clear the device registration from the first PS system.
Registering the BD remote control with another PS3system will clear the device registration from the first PS3 system.
For details on the BD remote control, refer to the instructions supplied with the remote.
SOURCE: problems to register (pair) the BD Remote Control PS3
Be sure to only press enter and start. I was accidentally pressing the direction ring that surounds the enter key. This was preventing the pairing from working. You must press the enter key with your finger nail.
SOURCE: How do i program the Sony BD remote without the
Use a game controller to look under System Settings - > Accessories. Choose Register BD Remote.
SOURCE: Nre Sony BD/Playstation Remote Control
yeah to pair your rmote you have to register it in the
Settings then go to
Accessory Settings then go to
Register BD remote control not Manage blue tooth devices like PS tells you to.
then do the whole start enter scan bit
SOURCE: how do i program my sony bd playstation 3 remote
Hold START and ENTER while in the accessories section of your settings on your PS3. You should see a spot for the remote. That connects it.
SOURCE: I have a BD remote but do not have the actual PS3
Unfortunately you can't, you at least need a controller to get to the option in your setting to register a bluetooth device.
