SOURCE: Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
SOURCE: My panasonic copier is displaying U14. what does
You need to replace the waste toner bottle or empty it and wash it out
SOURCE: I have Ricoh Afisio Copier and I have error code SC301
That mean that you have problem with the charge corona, i'm not sure for which model do you talk about but it should be when you open the front door it has one black wheel, under the wheel has a black oblong(the corona) from which come out a wire which is connected near, so when you will locate that part(the corona) you will see that the part is attached to metal plate with one bolt under, so unscrew the bolt and pull the corona towards you but carefully and straight to not damage the drum when you will pull out the corona you will see that inside has two or one string wire, see do the wire is broken if is broken it will need to be replaced, if the wire is not broken you will see do the part(corona is dirty if it is , clean it up with clean cloth or if you have on hand put some pure alcohol 96% on the clothe and clean it up after that insert the part(corona) inside. you can't make mistake on the path where you need to return it has a rails on both sides if you do not set the corona on the rails it will do not enter, do not use to much force if do not want to enter try again. after you will place in it place don't forget to attach the connect the wire and screw the bolt. When you will do this turn the machine on again and see do will the SC 301 disappear, if do not disappear you will need to call service because some part need to be replaced.
Please rate the post if was helpful for you for i to know does this was helpful or not for to know to post some more information
Testimonial: "thanks"
