SOURCE: memory card for motorola krzr k1
try formatting & inserting it again.......
it may solve ur prob
SOURCE: my nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
SOURCE: pny micro sd memory card
Most PCs are like that. I don't know what it is but the computer won't do it for mine neither. To put music and such on you sd card for your phone you must format the card while it's in your phone. Goto setting, Memory, Card memory, then click on opions. From there it will say "Format Card". Do it and the lock code is the last four digits or your phone number. After that's done to load music and such you put the sd chip onto you computer and transfer music to the folder on the sd card called "My_music", pix to "My_pix", and so on....
SOURCE: 3110c USB drivers
nokia pc suite installed in windows 98 will identify the phone after connecting the data cable
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
