After a full descaling programme, the descaling light still comes on - any ideas on how to reset this?
SOURCE: Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
SOURCE: Describe your Jura Capresso Impressa Z5 Espresso
will start by itself after it was shutoff for after
7-12 hours suddenly ? Why
SOURCE: My Saeco Italia is stuck in the descaling mode.
I had this problem too. I was beside myself wondering what to do. I took the machine apart but there was nothing wrong. It was stuck in an infinite descale cycle. The 5 green buttons never blinked to say it was done. What finally fixed it was to close the steamer valve to where water was being being restricted from the steamer wand but still a little water was spurting out. It finally quit emitting water and the 5 lights blinked and the infinite descale cycle completed. This model espresso maker was a lemon and been nothing but problems.
jeff
SOURCE: our saeco talea giro descaling
To remove a descaling light you need to hold down the steam/water button for 6 seconds and the light should go off. The button is located on the right side of the coffee button.
If you are in need of the manual you can download it here
