Set is only 2 1/2yrs old. Never any problems. Stopped spinning the other day. Clothes are sopping wet at end of the cycle. Will not engage spin mode at all. I don't even know where to begin to self diagnose. Any help would be a life saver.
Could be a number of problems,but try this FIRST push and hold any two buttons in for about 20 seconds make sure the machine is on,if this fails then you could have a blocked pump ie a sock is the usual suspect some mackines have a filter at the lower front check below the door if there is one then open and unscrew anty clock wise,if not then the pump will need removed and unblocked.adrianxxx
SOURCE: washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
SOURCE: wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
SOURCE: Kenmore Front loader Washer Problems
u need to remove the shipping bolts, found in the back of the washer, 4 long bolts used to hold the drum in place while transporting. we had same prob
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
