I am not able to power on the ipod after once the charging came down completely. It is not even showing whether it is charging or not and nothing can be seen on the screen.
Generally speaking, if you have connected it to a power source when it has completly drained it should display 'Please Wait, Very Low Battery' (without the backlight). If it does, leave it until that message disappears. Pressing the play button should now wake it. However, If you have been charging it for a while and nothing has been displayed the battery my be dead all together. With the iPod connected press the Select and Menu Buttons together until an Apple symbol appears (non-backlit) it should then startup. If it turns off when disconnected from the power then you have a dead battery. If none of that solve it I offer a repair service at a very low cost.
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo.
This error error occurs when the hard disk is unable to access the information and stalls while opening a file.
A reset of the device usually corrects the problem, as it clears the device's memory and any errors.
Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch.
Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position.
Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel.
Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo.
Plug the iPod's connector cable into the dock connector on the bottom of the iPod.
Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod.
Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu.
Click "Eject iPod" in the sub-menu to disconnect the device.
The iPod takes four hours to completely charge its battery.
hope this helps
hope this helps
