The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
machine needs to be level.so it cant rock side to side or front to back adj feet .when u load machine put half in and rotate drum half turn and put the rest of load in.that should balance load.dont overload.try running empty if it still showing ua
why the hell did you do this.. the power surge is what killed the tv..dont ever mix appliances in this manner.. you just fried the tv..any electric heater will be plugged in to an outlet by itself.. NO OTHER EQUIPMENT on the same plug..this causes fires and equipment failure..as you found out..the power strip wont handle the heater..check the reset button on the power strip.but unplug the heater..
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
