I need to know how to set the Timex CD Clock Radio for Daylight Savings Time. It appears that since this clock radio usually automatically set its own time and adjusts for time changes, leap year, etc., that I cannot adjust the time manually. Any ideas?
Solution # 2 hell me thanks
I downloaded the manual from the Timex website give in a prior post.Here is a link to the manual in PDF: http://www.mediafire.com/?cn1kusjfosx
There is a website where you can download a copy of the owner's manual: www.TimexAudio.com then click on Support Then click on Product Manuals Then select T309 from the drop down menu Cheers!
Additional note: after display starts flashing, you must first reliease the time button before the (<<)or(>>)buttons will change the time. Than press time button again to set the time. BY, Gene
Thank you - I was going to say there is no time set button, but it is underneath the top panel halfway hidden under one of the music preset buttons. Kind of a lame design, but it worked...
I was able to manually change the time. However, the problem is that last fall it automatically "fell back" on the original date. I didn't know that date so it threw me off since it is my alarm clock.
The Timex site is completely worthless. I did submit a question regarding this issue to Customer Service. Wel'll see what kind of anwser they give.
Does anyone know how to prevent it from changing the time on the original daylight savings times?
how to set time Sylvania Clock Radio SA85018-2
should radio be on or off
ITEM NUMBER# WRSSDX
How do you set the time on an inspired clock radio with iPod Dock as the manual seems to be missing
