Just bought a pair of the radios: one seems to be picking up faint signals all the time: I guess I have to adjust the squelch. How do I go about it? The other radio is fine. Thank you for your time. Massimo
SOURCE: I have a uniden pro
Turn up the RF gain, all the way and leave it there. Make sure the squelch is down.
SOURCE: pc78 elite cb
Hi, You may want to check your PA/CB switch (should be in CB position) by moving it up and down a few times. A Cal switch if present in your model normally stands for Calibration which is a feature to measure the SWR of your antenna and should not really affect the TX/RX function of the radio. If still a no go, you may have to seek the services of a qualified radio technician or bring it back to your dealer for repair/replacement. Good luck and hopes this work out for you. Pls post again how things turn up. Kind regards.
