1) LUBE the deck belt, this happen by lack of maintenance, maybe you have deck worn. 2) LUBE the rollers bearing too. 3) measure the input voltage motor, if there are the motor need repair. 4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. God bless you
Hi sir.
After reading his problem.
Please do the Maintenance and LUBE,
The error # 9 mean that thinking. [email protected]
cell+whatsAPP:+50588611441 How To Lubricate Treadmill
hi, Here is the steps to adjust the treadmill belt, (1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt. If then also the belt is slipping then you have to replace the running belt with a new one.
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same.
var fctb_tool=null;
function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']
var fctb_tool=null;
function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t)
fctb_tool=t;
start(fctb_tool);
FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
