My sunroof has recently become a pain in my ****. Here's the problem now. My sunroof leaks pretty badly when it rains. A few months back I had peeled off the lining that keeps the water out. Now, air comes in when I drive, which sounds like a window is open, and water occasionally seeps in when it rains. I cannot take it anymore. How do I resolve this problem?
SOURCE: 2005 Jeep Grand Cheerokee Sunroof Leak
have the sunroof gasket replaced
or buy one online cheap at sunroof doctor.com
hope2help shack
SOURCE: 1995 Jeep Grand Cherokee Laredo - sunroof leak
lift rubber edges and apply clear silicon sealant under edges let cure hose with water to test, if leak then seal edges of glass with eurothane sealant, not silicon will rot in sun within year
SOURCE: rain water leaks from overhead console (No sunroof)
common problem with these roof racks check for loose bolts holding it on also there are inserts pressed into your roof under the roof rack these threaded insrts tend to come loose or get pulled out use silocone sealant around every bolt and insert.
SOURCE: I have a 2004 Jeep Grand Cherokee with a V8. I
Water pump would never do that. pump either works or doesn't. You should have no heat 'till the engine is warmed up. Engine heats the water. If it was doing this before you changed the thermostat then the old one may have been bad. However, at this point, Id be looking to see if you have it installed with the spring end towards the engine, if the electric fans are coming on and if the radiator is internally obstructed and not flowing properly. You need to re-fill the system with the heat on full hot and the fill cap off to ensure that air purges from the system. If equipped with air bleeds, use them as well. One trick I use to prevent air binding is to warm up the engine to the point that the temperature is just below where it normally runs at. Turn the engine off and wait about three minutes for the stat to open and then begin filling slowly till it's full.(running) Used to be you could check radiator flow by putting your hand on it in different spots when hot. Cold spots would be where flow is restricted. Today radiators are not easily reached but most good shops use a heat sensing gun to check this. If your radiator fills through a cap on the radiator if you need to dribble coolant in or it backs up, that is a good indication that the radiator is obstructed as well (providing t stat is working.)
SOURCE: heater core leak in 2002 Jeep Grand Cherokee Ltd
I have 2000 jeep grad cherokee. I have noticed some radiator leak once a while, then was increasing and the light was going on every 3 days or so. So I added STOP LEAK and it did stop, but now the heater is blowing cold air...How can fix this problem? Thank you.
Interior Fuses
The fuse panel is on the lower instrument panel just to
the left of the steering column.
1 30 Amp Green Audio Amp (B+)
2 15 Amp Blue Sunroof (B+)
3 10 Amp Red Htd Mirror (EBL)
4 20 Amp Yellow Rr Pwr Out (B+)
5 10 Amp Red Rr HVAC (R/O)
6 10 Amp Red OCM (B+)
7 20 Amp Yellow Door Locks (B+)
8 15 Amp Blue Steer Col Lock (B+)
9 20 Amp Yellow Pwr Outlet (B+)
10 10 Amp Red Ign Run Only Out (R/O)
11 Spare
12 10 Amp Red Mem. Sw, Courtesy Lamp
(B+)
13 Spare
14 20 Amp Yellow Cigar Ltr (R/A)
15 10 Amp Red Tire Press Mon (R/O)
16 10 Amp Red SCM, Cluster OBD (B+)
17 15 Amp Blue Flipper Glass (B+)
19 10 Amp Red OCM (R/S)
20 10 Amp Red WCM, Cluster (R/S)
21 15 Amp Blue Autowipe (Accy Delay)
22 15 Amp Blue Rear Wiper (B+)
24 10 Amp Red PDC, FCM, A580 (R/S)
25 10 Amp Red ABS, Trans. Case Switch
(R/S)
CB1 20 Amp Cycle -Wipers (B+)
CB2 20 Amp Non - Cycle Seats (B+)
CB3 20 Amp Non - Cycle Windows (Delay)
