I left my phone on night ring over the weeknd (like every night & weekend) and now my feature button won't release it from night ring.
SOURCE: Norstar m7324 - forward to outside line
The solution for someone using the administrator phone (receptionist phone) is after discovering you have a fax call, depress the <link> button. Dial the fax number, wait for it to answer, then depress <link> again. This places call 1 with an outside number.
Apparently this is also available if you have a feature button by depressing <feature> <7> <1> instead of <link>. I haven't tried this so don't take my word for it.
This can also be used to forward a caller to an outside line, such as a cell phone. In the manufacturing business, our shop manager is never in the office. I may ask him if this is a viable solution.
SOURCE: rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
SOURCE: Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
SOURCE: What is a Norstar Overlay Template?
right top Show
right bottom Next
left top Heading
left bottom Back
SOURCE: My phone on our Norstar system rings & rings
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
That did it!!! Thank you. Apparently that is the one button that came "unprogrammed" when the power went off over the weekend. Thank you.
