Problem Event Name: BEX Application Name: Explorer.EXE Application Version: 6.1.7601.17567 Application Timestamp: 4d6727a7 Fault Module Name: StackHash_e98d Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Offset: 6220c225 Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: e98d Additional Information 2: e98dfca8bcf81bc1740adb135579ad53 Additional Information 3: 6eab Additional Information 4: 6eabdd9e0dc94904be3b39a1c0583635
Start
your PC and press F8 several times until the boot menu comes up. Then
select "Safe Mode with Networking". Now get some or ALL of the FREE
programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
i have bitdeffender antivirus
Try the anti-malware apps only then.
im done installing the software also in the scan so whats the thing i should do ? and then it found a virus ,,, then i fixed it .. but the problem is still there
Yeah typically there are many more than just one file affected in an infestation. I guess you'll be bringing it to a repair shop then.
tnx for your time...but i will try reinstall again my windows 7 ultimate 32 bit,
SOURCE: Problem Event Name: APPCRASH
try this
http://www.microsoft.com/downloads/details.aspx?FamilyID=b0c7136d-5ebb-413b-89c9-cb3d06d12674&DisplayLang=en
Hope It Solved Your Problem
Good Day
SOURCE: Itunes will not open it is 64 bit and 8.1
I would uninstall Itunes, then download the latest 64-bit version HERE and re-install it. There are two different versions, you probably got the 32-bit version by accident. Good luck!
thank you for your time..but i will try to reinstall again my windows 7 ultimate 32bit..
